gsr in a cx hatch
whitegsrhatch
i got a 92 cx hatch and a 95 gsr. im using the cx harness and a sub harness from hasport. the local performance shop said that i needed a obd1 gsr harness, but hasport said that i could use my cx harness and the subharness that i got from them will work. i got the gsr to start up and it idealed funny and it wouldnt rev werth shit. P1 said it was cuz a gsr needs a gsr harness. who the fuck is right?
i took the wiring harness off my 95 si del sol. it had a d16z6 in it the harness was a sohc vtec harness and it would not plug up to the car. cx's are not wired up for vtev and you cant just plug up a vtec harness. the motor will start up and it will ideal but it want rev.
its a 92 cx.. if so it has vtec.. somethin ealse is wrong the harness wouldnt limit you revs.. your ecu will
what all is done to the car?
