GSR in ef speedo cable question
Discussion in 'HYBRID -> ED-EF / DA' started by Jayyycobb, Dec 5, 2008.
  1. Jayyycobb
    Jayyycobb Junior Member
    Brooklyn, NY
    If I am doing an obd1 gsr swap into my 91 civic, which speedo gear would i use, will the ef cable go directly into the gsr tranny speedo gear asssembly? I believe they are different...
  2. D16SiHatch
    D16SiHatch New Member
    they are. you need a cable speed sensor from a 90-93 integra
  3. Jayyycobb
    Brooklyn, NY
    Ok, I have one but, it has 3 outputs on it, are there power steering lines that go to it?
    heres a pic of it...
  4. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    They are different but they have the same tooth count on the gear. Use the SOHC one, it looks better and you dont have to modify the top of the sensor to get the cable to go in the hole.
    The 90-93 integras have powersteering, thats what those line are for. you dont need them if you use the integra sensor. Plug them though.
  5. Jayyycobb
    Brooklyn, NY
    Thank you for the response, you are a good man...^_^
    Can i use the one from my d15b2 automatic that i will be pulling in a few weeks?
    How did you squeeze the 94 teg cluster in your ef, does it fit flush with the trim?
    If i were to use the 94 teg cluster with my OBD1 gsr swap couldnt I just get a 95 GSR speedo cable and use the gsr speedo gear that comes with the tranny?
  6. D16SiHatch
    heres the pics you wanted..
  7. Jayyycobb
    Brooklyn, NY
    That looks so sweet!! :eek:
  8. D16SiHatch
    Heres a pinout i made for a 90-91 Crx/Civic Si to 94-01 ls/gsr/type r cluster. It actually kind of works out nicely the way these clusters are designed. when mounted in the civic dash anyway, can't vouch for crx, the bottom 4 indicator lights you can't see at all. the 4 lights are for maintenance required, low fuel, cruise, and SRS. luckily our cars don't need or have any of these features so it works out lol
  9. Jayyycobb
    Brooklyn, NY
    Thanx man... :)
    I have a 91 DX 4dr
    Do you know if this wiring you have listed for the 90-91 crx/civic Si will work the same on a 91 DX? :rolleyes:
  10. D16SiHatch
    They are the same
  11. Jayyycobb
    Brooklyn, NY
  12. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    i just used the speedo gear and cable from my ef and popped it into my 95 gsr trans..worked so far. aaand was that teg cluster in the ef hard to do? the 94 uses an electrical vss howd you get the speedo to work?
  13. D16SiHatch
    i wired up a 92-95 civic electronic vehicle speed sensor
