I am planning on swaping a Gsr motor into my 99 civic si. I was wondering how hard this would be. Im planning on getting the motor from HMotorsOnline so it should come with all of this: B18C 94-01 (GSR) Complete Change Over Price: $ 3199.00 Plus shipping and handling. Availability: In stock and ready to go. - Motor - Hydrolic Tranny (S80, Y80) - ECU (P72) - Axles with Half Shaft - Shift Linkage - Stock Motor Mounts - Alternator - Starter - Clutch - Flywheel - Intake Manifold - Exhaust Manifold - Fuel Rail - Injectors - Distributor - Engine Harness - Comes With All Sensors Needed - LSD Tranny (Optional +$300) Motors average 35,000 miles and come with a 100% start up warranty. All Sensors are guaranteed not broken and in working condition! Other than replacment belts and stuff like that will I need anyhting eles to make this work. Any help you guys could give me would be greatly appreciated. P.S. If anyone knows about a walkthrough for doing this swap please tell me so I could check this out, I want to learn as much about the procedure before I do anything thankx
i dont get why you would swap out our b16 for the b18c, yes it has more TQ and HP but wit the money you are spenting for the other motor, u can just buy a turbo kit and run 6psi on stock internals.
The reason I am doing a motor swap is because my b16's tranny is going out and it is probably 1500 to 2500 to get a rebuilt or new one so I figured that if I could get everything (engine, tranny, ecu, ect) together for 3200 it would be worth it.
