GSR into CRX si
Discussion in 'HYBRID -> ED-EF / DA' started by sihatchback_RL, May 19, 2005.
  1. sihatchback_RL
    sihatchback_RL Senior Member
    i'm swapping out my gsr in my hatch into my crx si. i bought a package from hasport, any body can give me any advice on this swap such as wiring, ecus, anything that will help this swap go easy.
  2. sleeper_crx88
    sleeper_crx88 Member
    first of all you will need a conversion harness (obd0 to obd1) im assuming thats the obd of your motor. granted that you want to run obd1 in your crx. then you will have to modify the engine harness on your crx to work with your new motor, the difficulty to vary depending on the model of your crx. si and hf being the easier ones to modify. i beleive its like 7 wires that you have to add to your harness for the motor's sensors. i think thats it...sorry if i come off as a know it all but i did this swap in my crx si and just trying to help with whatever i can hope its useful to you..
  3. Estorvito
    Estorvito Soy Boricua
    Orlando FL
    This might help......
    READ READ READ buddie... :p
    HOPE IT HELPS
  4. droppedcrxsi
    droppedcrxsi Member
