GSR into my 88 crx question
halo_freak101
I just bought a 88 crx si and i have a del sol with a full gsr obd1 swap. I was wondering if i can put the gsr into the crx and the crx motor into the del sol without any problems.
i'm not trying to be a dick but youll learn more by searching for what you want....
1.the tranny from the sol is hydrolic not cable like the rex
a. youll ned mounts for the crx
b. youll need shift linkage
c. you might need a harness
2. why would you want to put the engine in the rex? its old the sol is a better platform.... thats why i got rid of my crx
3. SEARCH we have tons of info. that way if you have more indepth questions we can answer them.
and finally DONT DO IT keep the sol... its a 3rd gen crx and a better platform
do you know the difference between a smart man and a wise man?
is this a track only car?
any pics of the two?
have you checked the bushings and suspension/brake components on the crx? before you swap you might want to look into that first
good luck
yes i will be turning the crx into a track car, and the crx is in mint condition because it is my friends car and he was the only owner.
for track only it would be great...
i would not put the crx engine in the sol.... i woul sell it like that OR put an engine in there with the same obd
