gsr or b16 head?
Discussion in 'Engine Building' started by DavEJ8, Jun 9, 2010.
  1. DavEJ8
    DavEJ8 New Member
    i'm building a ls vtec and want to know which would work best a b16 or gsr head?
  2. Magana559
    Magana559 The Warden
    fresno Ca
    same thing. but you get higher compression with a GSR head.
  3. DavEJ8
    DavEJ8 New Member
    wow that was fast. thanks!
  4. DavEJ8
    DavEJ8 New Member
    which would get me more horsepower? GSR, right?
  5. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    Not a ridiculous amount more but it would result in a horsepower increase.
  6. BrutalB83
    Rochester Hills, MI
    The answer here really depends on what kind of a build you're doing. If you just want to slap on a stock head and go, then the GS-R head is probably your best bet. If you're going be rebuilding the head with after-market parts, then it doesn't really matter, just buy whatever head you can get for cheapest...
  7. Magana559
    fresno Ca
    on a stock head swap, you will only get about a .2 compression bump.
