gsr pistons
racintweek
i searched and found nada
i know i cant use gsr pistons on LS rods
can i use gsr rods and pistons in an LS
Yes, but you'll lose quite a bit of static compression because the rods are shorter... if you want to effectively use GSR pistons and rods in an LS block, you'll have to use the GSR crank too.
why not just get b16 pistons? pr3 pistons will fit on ls rods, if im not mistaken....
unfortunatley no
i guess ill just look for pr3's or p30's
thanks
