Ive got a 1994 GSR motor, decided i wanted to run BC head internals so i got a PR3 head and had the local machine shop install BS cams, valves, springs, and retainers in it. After i got the new head I got a new head gasket as well. Installed the new ARP headstuds, set the head gasket, set the head and did a first torque of 20 then final torque of 65lbs. Timing is set correctly. went to start the car and it didnt fire. So i got out my compression tester and im baffled by the results. cylinder 1 is 30psi, cylinder 2 is 60psi, cylinder 3 is 85psi and cylinder 4 is 95psi. There is no binding of the valves, or any of the internals, i hand turned the crank countless times before i tried to start it to make sure everything was good. I have no clue what is happening. This isnt the first time ive replaced a headgasket on a b series. I have no answer for this one. I ran the car two days ago to get it out of the garage and it didnt have any problems then...
Any help will be greatly appreciated,
Thank you in advance
