Gsr rod knock!!!!!!
Discussion in 'HYBRID -> EG-EK / DC' started by GmodKid, May 30, 2012.
  1. GmodKid
    GmodKid New Member
    So I have a fucked up bearing!!! Don't know which one exactly but I believe it's cylinder 4!
    My question is this; is it possible to use gsr pistons on ls rods?
    Are ls cranks usable in gsr blocks? If any of this is possible what other parts would I need to make this work?
    I am tight on money and have only about 300$ to spare I would have loved to fully build the motor but cannot at this time. Any input is greatly aprreciated fellas thanks in advance
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Sucks to have a bad bearing, I feel for ya. :(
    GSR pistons on LS rods, not sure- one engine has thicker rods than the other, not sure which.
    LS crank no problem. Match with LS pistons.
  3. GmodKid
    GmodKid New Member
    I would basically have an ls-vtec in a gsr block with that wouldn't I? Would it be reliable? Thanks for the input cal:D
  4. phunky.buddha
    It'll be as reliable as you build it- use crappy parts and cut corners, and it'll die, GSR or LS/VTEC. Just so you know, my last B block was an LS crank inside a GSR block.
  5. whiterabbit06
    Crestview, Fl
    Your compression is gonna drop.
  6. GmodKid
    GmodKid New Member
    I'm going to be using stock parts. My parts list;
    Gsr pistons
    Gsr rods
    Ls crank
    Acl bearings
    Arp rod bolts
    That's my list so far. Are these parts compatible with each other?
    If so what else would I need to have my block ready again?
