gsr running bad
crxjoe
yo i need some help. my 94 gsr is running bad its revs from 1000rpm to 3000rpm just idleing an it has a tramendous loss of power. and wont rev high. pleze help me out
check your distributor, cap and rotor. as well as the plugs and wires. replace all and make sure your running the right dizzy for your motor/ecu. most likely its something stupid, vacuum leaks, wiring issues. take it to a tuner if all else fails.
it could be alot of things, but i would also say check vacume lines.. maybe check where your iac valve is make sure you have the write plug on it..
