hey i just bought the nitrous direct port plate for the gsr off a buddy, my ? is should i leave the secondaries in with the nitrous plate or should i remove it and just use the nitrous plate??? and if anyone has ever used this what gaskets do i get for it?
No the GSR kit bolts in where the secondaries sandwich between the 2 halves of the IM. You have to remove the secondaries to fit that plate in. Get the OEM gaskets from Acura for this.
Originally posted by nfn15037@Mar 23 2005, 09:08 PM No the GSR kit bolts in where the secondaries sandwich between the 2 halves of the IM. You have to remove the secondaries to fit that plate in. Get the OEM gaskets from Acura for this.
Originally posted by nfn15037@Mar 23 2005, 11:08 PM No the GSR kit bolts in where the secondaries sandwich between the 2 halves of the IM. You have to remove the secondaries to fit that plate in. Get the OEM gaskets from Acura for this.
