94GSRB20swap
I have a 94 integra GSR. i blew the engine so i dropped in a B20b with about 32K on it.
Rebuilt LS trans
New Clutch
9.5 lb flywheel
new slave cylinder
short shift
chipped P06 ECU
ill even throw in the GSR ECU if you want it!!
new radiator
new drilled slotted rotors, pads, rear calipers
cold air intake - K&N filter
full race exhaust edlebrock glasspack, Greddy box
17" rims (black) with new tires
new upper control arm/ball joint (camber kit)
lowering springs
decent stereo
...theres more im sure.
it has a few sensor codes, and needs some wiring... to somebody that can fix some minor issues they would have my finished project... thousands into this car!!!!
runs fine, drives great!! i just dont have the time or the patience to fix this...
i payed 1800 for the car before i did everything to it.
i have over 4000 into it.
needs some very minor body work, honda rot in the back ... needs paint. (the last step i never reached)
Im asking $3500
or give me an offer. this is a great shell, with that value alone in parts... not counting the labor it cost to put them on.
the interior is mint too... one piece missing from the headliner
Rebuilt LS trans
New Clutch
9.5 lb flywheel
new slave cylinder
short shift
chipped P06 ECU
new radiator
lowering springs
decent stereo
Im asking $3500
