gsr swap in my da please help
htda
ok got a obd2 gsr motor that i want to run in my 90 da here goes a list of parts that i got so far
1.obd0 to obd1 convo harness
2.p28 ecu
3.obd2 dizzy(which i have to make a jumper for to my obd0 harness)
so do i need any thing else to make this start right up and work perfectly or do i have everthing. also do i need to use anything else of my old engine.
thanks for ur help in advance.........
i just put a gsr in my 90 DA. the parts you listed is a good start. you will need to use your ls throttle body unless you have a gsr throttle cable they are different. it will bolt up. if you pm me i will tell you how to put it together so it works fine. you will also have to run your ls injectors unless you want to rewire the system for obd2 injectors but there is no point to it im running my ls ones and it runs fine. pm me and i will explain more for you if you want.
