gsr swap.... what about the fuel pump???
rrz69
i just swapped my si del sol(d16z6) with a jdm 98gsr. i was just wondering how important it was to change the fuel pump? will my stock one put out enought fuel for the motor. i drive it and it feels like it gets enought fuel. so i mean ppl tell me to change it but idk what do u guys think??
I believe the stock engine and the one you've swapped in both use the same injectors, so I don't know why the fuel pump would be any different either. If yours is tired then you may want to upgrade, otherwise I think you should be fine.
hey i have a question for you. how did your swap turn out? are you happy and how did you pin the knock and iab sensors? i wanna do the same exact swap when i get home from south korea(im in the military) id appreciate any advice you can give me
