gsr swap
8ballsin
im going to be droping in a b18 GSR motor and tranny i was wondering everything that needs to be converted i know so far i have to get the conversion harness ecu what else do i need to swap It is going in a 1990 CRX Si
you need,
mounts,axles,probably diff. hubs,the ecu for the gsr(or chipped p28),shift linkage,and time
and hydro-cable conversion
OBD-1 conversion with obd-0 to obd-1 jumper harness. Ecu options P28 which you can reprogram/p72(GSR)/P73(Type-R)
