Originally posted by civicious@Jan 22 2004, 08:35 PM
you can use the b16 tranny (but you shouldnt), and youll have to use the wiring harness that's in there.
Originally posted by highperboi@Jan 22 2004, 10:55 PM
i got a gsr tranny and i get 35mph so i think the ls would get more.
Originally posted by civicious@Jan 22 2004, 10:35 PM
but if you must, all you'll need really and truly is the gsr longblock. you can use the b16 tranny (but you shouldnt), and youll have to use the wiring harness that's in there.
oh, and youll have to re-pin your ecu to work with the p72 if you use the integra ecu. you should jus get a jumper and an obd1 ecu.
Originally posted by revolution8k@Jan 24 2004, 04:22 PM
As far as I know the GSR never had an LSD in it, you're thinking of the Type R transmission.
Personally...I would stick with the a2 tranny and get a Quaife LSD.
