What should I expect to pay for parts to rebuild that motor with oem parts
Well the ecu should be a P75 for a B18b1, the harness will have the two extra plugs by the dizzy for the vtec... Pull the ecu out and get the numbers but if it runs good then it most likely is a P75..
First part of that journey only costs an internet connection lol. Read around here and you can get a good idea of what you want this rebuild to be. The actual OEM parts aren't that expensive....depending on the "rebuild" but I figure a nice refreshing of the motor.....
piston rings, bearings and a make shift honing. Plus a valve job, timing belt, oil pump, water pump, etc, etc (if you choose)
Would it be better to just switch the gsr head to the Ls block????
Hey CAFROG that part is ok his car is a EX model...lol
