gsr tranny vs b16 tranny
Discussion in 'HYBRID -> EG-EK / DC' started by viejo, May 9, 2010.
  1. viejo
    viejo New Member
    im putting a b18b1 in 97 civc, i would like to know which tranny would be better, and also would like to know what there better for. Advice will be appreciated!
  2. FLounder
    FLounder power hungry VIP
    north palm beach, FL
    if you do a lot of hwy driving, get the GSR transmission. the slightly higher gear ratio in the upper gears is nice. other than high cruising rpms the b16a trans is great for a sub 200whp setup. the short gears will wake it up. dont get me wrong though, the GSR trans has noticeably shorter gears than a LS tranny and will work great too.
  3. nicefighter80
    nicefighter80 New Member
    b16 trans is geared higher, I run a b16 trans and at 65-70 mph im at 4000k rpm in 5th
  4. Briansol
    b16 = faster acceleration, weaker diff, good for drag/race, will use more gas and ware at highway speeds due to elevated 5th gear rpms
    gsr = slightly slower acceleration due to longer gears, better daily driver, strong diff center
    Daily driver with highway commuting, i'd go for the gsr
    pleasure car only, b16
    either way, try to get an LSD in either :) 2wd > 1wd
  5. 34diesel34
    34diesel34 Import Tuner
    USA
    B16 tranny gears are short as hell. Im on the express way on the way to work and 5th gear in my B16 crx feels like 3rd gear on my accord and it's at 43-4500 rpm.
  6. Lumpskie
    Lumpskie Member
    Here's another data point:
    My GSR trans runs around 4k rpm at 80.
  7. 34diesel34
    USA
    B16 is at 4500rpm at 80mph in 5th gear:mellow:
  8. eg6sir
    its actually 4400 rpm
  9. jbdakid
    jbdakid Member
    I have a B18B, I just put in a B16 trans but I installed an LS 5th gear! To me, that's the winning combo!!
  10. CAFROG
    CAFROG Honda Minion VIP
    NOR-CAL
    ^^^ my plan when I rebuild my trans....I hate the B16 5th gear
  11. eg6sir
    i had the same plan years ago.. never did it though.. b16 gears w/ ls 5th for freeway driving FTW!
  12. CAFROG
    NOR-CAL
    The gear isn't that expensive either...just a matter of cracking that case open and changing it out (which is the scary part too lmao)
  13. eg6sir
    exact reason i never did it.. and i'm not payin anyone to do it.. lol
  14. Magana559
    Magana559 The Warden
    fresno Ca
    b16 trans is great for acceleration, but sucks on freeway.
  15. ipwnheaton
    ipwnheaton New Member
    where to find b18 ls gsr or type r tranny?
  16. E_SolSi
    classifieds sections on forums like this one
    engine importer sites sometimes have them
    local junkyards
    ebay
    craigslist
  17. intenseneal
    intenseneal New Member
    I like my LS S80 trans, gears are not to long at all. The GSR trans is the best for a street car IMO. Has slightly shorter 2nd and 3rd than the LS 1st 4th and 5th gears are the same. I cant really tell the difference in gearing from my LS and a 00 GSR I work on. For racing the ITR trans is by far the best. Stronger dual syncros, short gearing, LDS.
  18. lostsoulzprophet
    lostsoulzprophet delslow
    georgia
    heres my stand point i have a b18b with a b16 trans. town driving its great on the acc highway like they say 4k rpm at 70 not great on gas.
