dhaccordLT-R
ok, in a 94 gsr transmission, there are the counter shaft and the input shaft, where they go into the case housing, are there supposed to be a shim/washer there?. my problem is that i cannot get the case on top to fit together as one and i heard that the problem of shims might be the root cause.
