gsr vs itr
Discussion in 'Engine Building' started by zackzerr, Aug 31, 2014.
is a set of itr cams worth $400?
  1. yes on ebay the intake cam is $350 in used condition
    100.0%
  2. probably not
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. zackzerr
    zackzerr Member
    st louis
    hey everyone im about to start the process of converting my lsvtec dd to a turbo dd.. its a b18a1 with gsr head. i have a set if itr cams laying around. i measured my gsr vtec lobe and it seemed to be taller than the itr. but my secondaries were quite a bit smaller... obviously i want fuel economy when cruising not in vtec but more power in vtec. should i install the itr cams or sell them? im only going for 12 psi as its stock with arp head studs... thanks for the guidance
  2. Briansol
    You'll want to do the springs/retainers as well if you do go the ITR route.
    lots of guys make good power with gsr cams, but the itr cams make a little more if they are gear-timed right to reduce a bit of overlap (-1i/+1e ish)
  3. phunky.buddha
    Dallas / Fort Worth, TX
    If you can sell them for $350-400 I'd do that. You can buy much better cams for that cash- the difference between the GSR and ITR cams isn't humongous.
