GSR won't REV past 3300+ RPM
Discussion in 'Integra' started by Duran816, Sep 15, 2008.
  1. Duran816
    Duran816 New Member
    Newberg OR
    I pulled a couple of plug wires on my MSD Ignition system that fried a bunch of stuff.
    Since then, I have replaced the MSD Blaster 2 Coil, my OBD1 Dizzy, Ignitor, ECU (x2)and Main Relay.
    Now, it just purrrs at idle (1000 RPM), but when I try to REV it, it won't REV past 3300+ RPM???
    When I do, the motor wants to BOG DOWN and will SPUTTER off and on...
    I checked the TPS Sensor, my Fuel Pressure is good @ 40-50 psi.
    It's like it is REV limiting, but at 3300 RPM.
    What gives??? It feels like it's an electrical issue or a sensor or something, but where to look next??? Which sensor? Could it be the wire harness?
    :( :mad:
  2. blakeyBOY
    blakeyBOY New Member
    you check the MAF sensor?
  3. prpprimo
    prpprimo Hondaholic
    ABQ
    Is this a recent swap into your 88 crx? Did you do a dp to mpfi conversion?
    Which injectors are you using?
  4. George777
    George777 ^^ Likes Bewbies
    With your mom
    Check for CEL. Clear those codes, and then see if it still does it.
  5. spoondb2
    spoondb2 New Member
    check your ecu or tps or maf
