Guess who just bought a 95 Integra...
Well, I took apart one of those little usb car chargers that goes into the cigarette lighter and soldered the usb wires from that plug straight to the chip in the charger. Then I soldered a power wire and ground wire to the part of the chip that is for the lighter and ran the two to the radio power source.
So, I'm looking at my chart for B series transmission gear ratios and I'm thinking that if I swap out the 5th and final drive gears from my B18A1 trans with the ones from a B18B1 trans, I can get the Fastest top speed of all the B series transmissions. The gear ratios and approximate top speed at 6800 rpm with 205/50/15 tires would be as follows:
1st 3.166 35mph
2nd 1.857 59mph
3rd 1.259 87mph
4th 0.935 117 mph
5th 0.714 153mph
Rev 3 36mph
Final 4.266
Lol...Yea, I know. I'm not so much worried about 5th gear because I know that's a stretch. The final drive will affect all of the gears and still give me the higher top speeds in each gear from 1st through 4th, which I know I would get to. So... maybe just the final drive then?
Ok then, maybe not...it worked nice when I used those gear ratios on gran turismo...lol. I need to worry about getting the rest of the stuff to do the swap anyway. I just gotts be patient. I'm gonna start doing the wire tuck in the next couple of days. There is a bunch of shit in the bay, between wiring, the ABS system and the A/C system.
Some stickers I made at work.
I'll let you know, I have a few ideas, I'll text my friend who I know wanted some as well.
Ok, so I'm obsessed with Mario...
BTW, I'm redoing Mario so he'll be pixelated and in color to match the rest. The coin is in reflective yellow.
attachment.php
I pulled out the cruise control system, so if anyone wants it msg me. I have the control box, the actuator, the cable, the bracket for the accelerator pedal and the plugs for them.
How much for the cruise control system? Are you gonna boost that thing?
Sweet, man! Looks good! Loving the Mario stuffs!
What brought you to Crestview?
Thanks, I took off the stickers on the side window and the sunroof and put different ones on the windshield. I got transferred here for work.
attachment.php
Haha! I like it across the rear window...
Any chance you'd like to mail me a "set" ? :)
Quantos Amountos?
Unfortunately I made those at my last shop and they don't have the stuff to do it here at my new one. :(
