Deanireland
From Ireland my words mite be a bit diffrent..any questions just ask...
Ek conversion:what u need
engine And box.
Just engine loom and Ecu.
Drive shafts half shaft.
Gear linkage b and d are not the same.
Side mouths are the same wil need back b mount.
How to change:
Remove battery.
Open battery tray.
Unplug Ecu and loom.
Remove engine loom.
Open shafts with 32 socket.
Jack car up if don't have engine liff or crain.
Open gear linkage
Open manfold
Remove rad
Remove manfold
Open power stearing
Open fuel line
Open hubs from top
Remove the drive shafts
If I'm shure engine should be ready..
Take of the back mount.
Remove passinger mount and the drivers engine wil drop make sure it's low to the ground then jack the car up and pull the engine and box out
engine And box.
How to change:
Remove battery.
Open battery tray.
Remove engine loom.
Open gear linkage
Open manfold
Remove rad
Remove manfold
Open power stearing
Open fuel line
Open hubs from top
