78civic
I've got a major problem going on with a 88 civc auto 4dr.
Had it sold and the new owner was driving me back from the test drive, and it started to sputter and died right in my driveway..
Had to give the money back (just on moral principle) and have tried all sorts of things..
SO, checked codes and it was showing crank angle sensor.
Changed out dizzy with my 90 4dr and it showed same..
put the 88's dizzy in my 90 and the 90 fired right up and ran fine.
Put the 88 back in the 88 and same code..
Went to a yard and picked up a auto ECU for the 88, swapped in and now NO CAS code.. NOW injector code. (pulled injectors while there) so I changed them.. and then showed CAS code.
GOT frustrated and went to a yard for another harness.
swapped that all in and guess what?.. NOW it's showing a CAS and injection code.
I'm about ready to torch this thing but it's just too nice and need to sell it running correctly.
I'm going today to swap another dizzy and or parts (cas) to see if that helps or changes anything.
I'll be back here later today and check up if there is something that I haven't tried.
And yes. I did check the ground on the T-stat housing.
E
E
