h/g blown?
crx
funny thing started to happen when i put ampm(always chevron) gas in on saturday, as soon as i finished pumping i started the car and it was running on 3 cylinders, i was like weird. so i pulled over and poped the hood i though a spark plug wire come off or sumin. i checked and its all good, so i take off alittle while later the car starts over heating, temp goes up and down up and down. now some times when i start it, it seems to miss for a min then runs fine, but some times it over heats or starts to. my fan works, the rad isnt leaking, timing is good,plugs are gray/tan, heater works, i figured it was air in the system, so i bled it took the rad cap off and let it idle for like 5 mins, the bubbles never stoped. also theres no oil in the water.
i got this engine(looked very good) and swaped it in to my hf
i have no codes and im kinda lost
d16a6
thanks
-joseph
you said it was bubbling whne you took the radiator cap off while it was running? That's most likely the head gasket man. Get it fixed.
