KYB AGX's would be a good match
as far as wheel spacers, it's typically a cheap way to make room for brake clearance. it's also not a really good idea, as the centerline of the rim doen't pass thru the centerline of the hub, which puts more stress on the wheel bearings. the proper way to make room for larger brakes is a larger diametere rim and a differnet wheel offset.
