h22 accord
Discussion in 'Accord' started by H22 9accord2, Mar 2, 2009.
  1. H22 9accord2
    H22 9accord2 New Member
    BIG town of ELLERBE N.C
    i need help i have a 92 accord i done a h22auto swap and have changed it to a stick now my vtec isn't workin since, im startin to think i should have left a auto it revs line at 6500 like stock motor no good without vtec now can any body please help
  2. Hondadude141
    TX
    Did you change your ecu?
  3. tifysue
    tifysue New Member
    Picayune, MS
    dude its in limp mode...my car did the same thing
  4. H22 9accord2
    yea i changed the ecu its a p13 man what up with limp mode and how do i fix it??? i need help it makes me mad i done the swap auto to 5sp and my vtec quits i just bought a nother accord today just 4 parts 5sp i was gonna changed the wirein harness and c if it helps but i hate 2 do that it makes no sense to though it worked and then it dont please let me know what i can do
  5. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    change the harness because the harness on the auto and manual is different, and that could be a problem....when i did my h22 the thing stalled out when i tried to move and when i turned the car off and took the key out, it was still running, all because of the oil pressure sensor not wired up haha, but yea, do the harness because with hondas....stupid small wire problem could turn into huge problem
  6. H22 9accord2
    you really think that will help i hate 2 do it and it not make a dif know what i mean but it makes no sense it worked fine with the auto would u change the whole wirein harness inside and out or just motor
  7. tifysue
    tifysue New Member
    Picayune, MS
    mine 5 spd h22 accord is STILL rocking an auto harness...do you have a check engine light? if so whats ur code? there's a reason ur in limp mode and i doubt its the harness
  8. H22 9accord2
    whats limp mode? and yes is throwin code 36
  9. MthaFuknGreen
    Lodi, CA
    36 traction control found on JDM ecu's
  10. H22 9accord2
    so what do i do to fix it?
  11. MthaFuknGreen
    Lodi, CA
  12. H22 9accord2
    does anybody know what it might be please help and can anybody tell me what limp mode is
  13. Hondadude141
    TX
    He did just give you two places to read up, basically check your ecu to see if it is a JDM ecu and if so then it needs to be replaced with the USDM ecu, that was one option.....
