h22 H-gasket on h23?
ripcord
anyone know if the h22 gasket would work on the h23? i know the major differences are places for vtec hard ware oil and what not. if this doesnt work anyone know where i can get a thicker h23 gasket?
the only way to get a thicker headgasket for a h23 is getting a copper gasket from SPC, then you have to oring the block, i had the same problem, i just used stock, wiseco requires .040 piston to valve clearances but i have had no problem running 10-15 psi
gasket
spc? sorry been a bit since i have been into imports a full name or web address would be great. thanks for your help
ok i just got done with my mini me swap...there is a pin in your block for the oil line...you take it out with a pair of plyers....simple as that!!
