H22 Head on F22 Motor
Discussion in 'HYBRID -> BA-BB /CA-CD' started by kungfubrooks, Jan 16, 2003.
  1. kungfubrooks
    kungfubrooks Junior Member
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Not easily. Unless you have a vast knowledge of engine building and some spare cash, it's a better bet to do a full H22 swap.
  3. bjsurf1
    bjsurf1 Junior Member
    What exactly is difficult about putting an h22 head & intake manifold on the f22b1 bottom end. I compared the head gasket part #'s and both the h22 and f22b1 had the same part #. What else is different? I currently have a h22 tranny on my f22b1 engine so I know I won't need to change axle's just the head, intake manifold, and ecu, and a couple of wires. Im I correct or am I missing something?
  4. pissedoffsol
    the head won't just botl on. there is machining that needs to be done, and head stud positions moved.
  5. dohcvtec_accord
    The left lane
    Yeah, what he said. :) I'm also not sure what you need in the way of a timing belt, crank pulley, etc.
    If you want specifics, check out http://www.pfispeed.com
    They're a shop in Ft. Collins, Colorado, and they've put an H22 head onto an F23 bottom end. I don't think they're any info on their website, but feel free to give them a call if you're getting serious and want some info.
  6. prelude92stype
    prelude92stype Junior Member
    sohc and dohc heads cannot be switched easily. they arent worth the money when it gets down to it. Just get the whole swap.
