H22 In A Civic
riceburner5
i'm new to this post so pls. go easy on me. i'm almost done puttin' a h22a in my civic and i'm tryin to look for the knock sensor on the 92-96 prelude engines. how does it look like? also, all you h22 civics out there, what are those 2 air outlets on top of the intake manifold facing backwards. seems like when i plug both of 'em, the car start to die. what you do with those outlets. pls. help cause i need 'em really bad. thanks in advance.
first your knock sensor,
your knock sensor is number 112, its the red/blue wire.
and the the two on top facing backwards
The two that i think your talking about ..
One goes to the intake control solenoid valve (alot of people just cap it off, if you dont have emissions to worry about it, you might want to do this)
and the other goes to the EVAP purge control soleniod. And if these arent the two that your talkin about theres the diagram, look for yourself :p
If you need more diagrams, i got them for the civic and the prelude you can find them here.
https://hondaswap.com/gallery/browse.ph...hp?album_id=272
