h22 in a ek
Discussion in 'HYBRID -> EG-EK / DC' started by civiclxb16, May 23, 2005.
  1. civiclxb16
    civiclxb16 Senior Member
    Poconos pa
    ok i am thinking about putting an h22 in my civic got a b16 in there now and i am ok with it but i want more. i was thinking boost but i don't want to deal with turbos really i want to stay n/a with out spending 10000 on a motor. so i was thinking about an stock h22 with a small super charger. now what i wanted to know is what do i need as far as mounts and stuff. i know i need a mount kit. now i was wondering about the springs do i need to change them? and what should get? what about the linkage? i know they are cable trannys but do they make a customs linkage that is shaft? can anyone help me before i buy my h22
  2. nismogod
    nismogod Senior Member
    Deltona, FL
    i kept cable in my EG w/h22. its fine to me. SC would be fun, but a good tune with Type-s pistons would be cheaper, and you could spray it. only stressin it when you need to.
    i switched to integra springs, GSRs to compensate for the slight weight gain.
  3. nismogod
    Deltona, FL
    or you could buy mine. lol.
  4. civiclxb16
    Poconos pa
    buy mine and i will buy yours
    b16 4dr you can't go wrong with that!!
  5. civiclxb16
    Poconos pa
    so what axles do i use?
  6. nismogod
    Deltona, FL
    i went to gator. but there is a "compatible list" available. i can give you the numbr for gaotr if you want, its all garunteed. but you can mix-match parts if you want to get a usuable set of axles. lemme know
