h22 in civc
Discussion in 'HYBRID -> EG-EK / DC' started by redhondahatch, Dec 18, 2002.
  1. redhondahatch
    redhondahatch Junior Member
    I was wondering what it wil take to install a JDM h22 into 94 si civic hatch. I was wondering if I need a new ECU with the 94 si becaus it already has vtec and if the harness needs to be changed?
  2. paragus
    paragus Senior Member
    use a p13 (prelude) ecu or a P72 (gsr) ecu. But from everyone says p13 is the way to go. and yes your wiring harness needs to be changed. You want to use your civic wiring harness on your prelude motor connecting to your prelude ecu. Did that make sense??
  3. hybridsol
    hybridsol Senior Member
    ohio
    use a prelude ecu, the gsr ecu makes you lose power
  4. HenryOng074
    HenryOng074 Member
    definatly go with the p13
  5. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    How so?
    Either one will fit your needs, it's just a matter of which one you can get your hands on easier. They're both in pretty high demand.
  6. longlee
    longlee Junior Member
    a h22 into a 94 civic is not just changing the wires and ecu you will need to buy aftermarket mounts and modify your frame a little ...the mounts arent cheap so you better have about 600 bucks before you start your swap..
  7. longlee
    also you would need a aftermarket radiator too... the h22 will run into your stock radiator...
  8. E_SolSi
    all you need is a thin fan not a custom radiator
