h22 in civic prts / h22 prts / si / gsr / sparco / more more
midorihatch
Ok well here is my going H2B sale and some other random parts plus if you dont see it i might have it so ask cause it doesnt hurt.
ALL PRICES INCLUDE SHIPPING UNLESS YOU SEE (PLUS SHIPPING)
ALSO I DONT USE PAYPAL DUE TO BAD SERVICE FROM THEM SO I ONLY TAKE MONEY ORDERS BUT YOU CAN CHECK MY VOUCHES AND SEE IVE BEEN A MEMBER FOR SEVERAL YRS
One more thing I will take trades as long as I can use it on my 96 Civic hatch with H2b "h22 with b16 tranny" so i need b-series parts
Well with that being said lets start the sale!!!!!!!!!!
follow the abc key in pic
A - H22 alternator-$50
B - custom shifter box hole cover (keeps heat and fuems out)-$15
C - H22 starter-$50
D - H22 alternator bracket-$10
E - 99-00 civic SI proportion valve-$40
F - 96-00 civic firewall holes covers-$10
G - H22 auto timing belt tensioner-$40
H - Kaizenspeed balance shaft belt pulley replacement spacer-$20
I - H22 timing covers-$13
J - Earls oil return line-$15
K - H22 knock sensor-$30
L - 3 Bar map sensor-$40
M - H22 vss-$45
H22 into 96-00 civic Hasport mounts-$400
93-95 H22 rear tranny bracket used for h22 civic-$30
AEM cai used in, eg with b16/ ek with h22/ ef si-$100
H22a4 non sh 5 speed tranny no grinds what so ever has 70k on it (will throw in new stock clutch and flywheel if you remind me add $15 for shipping)-$400 + shipp
H22 shifter box with cables-$100
Sparco harnesses 3 point-$120
Honda OEM white diamond pearl touch up piant-$11
Random stuff
H22 stock dwn pipe-$30
GSR stock header-$50
H22 new stock clutch kit and flywheel-$75+ shipp
D16a6 (91 civic si long block for parts)-let me know what you need
EK rear interior panels the big ones-$40
ICE MAN intake no filter-$20
H22 in ek Place racing axles-$100+shipp
95 accord intermidiate shaft for H22 in civic swap-$40
Do you have the original H22 drivers side motor mount still?
knock
just wounder if you would send me the knock sencor. i live i Arizona
