H22 installation preps
Discussion in 'HYBRID -> BA-BB /CA-CD' started by Mulepick, Dec 9, 2006.
  1. Mulepick
    Mulepick New Member
    Nevada
    I've been researching stuff to do to the H22 prior to the swap to my 93 Accord. I've invited input regarding what I should do if I wanted to add a turbo down the road. I also know about the chain tensioner fix.
    I'll check the compression.
    Does anyone have a procedure to check the sensors prior to install? I sure would like to eliminate bad sensors as I'm sure I'll have enough problems with the VTEC wiring and the AT flap.
    Tks,
    Bob
  2. tab
    tab Super Moderator
    Aberdeen, Washington State
    You have the perfect swap car for that motor. You'll want the DOHC prelude power steering hose. You won't need to wire IAB into your harness, just VTEC and knock.
    It'd be very hard to test sensors outside of the motor, so just plug it in the car, and check for codes.
    Read my guide, it applies directly to your swap.
  3. Mulepick
    Mulepick New Member
    Nevada
    my h22's coming with a lsd AT. Did you have all the probs these other guys are having with tcus? Remember which tcu you had in there?
    I'll look for your swap guide.
    Tks,
