The 4th gen h22 swap is probably the easiest swap to do.
1) Is you car automatic or 5 spd?
2) Is it a dx/lx or ex/se?
If it's an automatic you can get automatic h22's (which are just as fast as the 5 spd, if not a tad bit quicker...just don't expect much after 115-120 due to the gearing).
If it's an ex/se trim line, you only have to wire up your knock sensor, vtec pressure switch, vtec solenoid and vtec groun.
Use your accord motor's wire harness and add in the extra wires.
If you have an ex/se an added bonus is that you can get a DC header for the h22 and it will bolt right up to your stock exhaust system!
If it's a dx/lx you'll have to get some welding done (and add in the IAB or just run a vaccum line from the IAB diaphram to the intake manifold..wait until you get the motor, you'll see what we're talking about).
Use you accord mounts, a/c compressor & bracket.
Either get a prelude power steering pressure line or use you accord p/s pump (you'll be short one bolt..but oh well).
It's super easy to do.
You don't need any fancy gadgets like VAFC etc for the stock H22.
Use the p13 ecu (and if you get an automatic, I've found the best TCU is a USDM h23 TCU).
Once it's in it should feel like stock with a sh!tload more torque and HP.
