h22 into accord q's
hondanewbbb
Swapped an h22 into a 94 accord. Damn thing runs like sh*t. Doesn't start for that matter sometimes, when i'm turnin the starter over the speedo goes crazy? When it does start it runs real mediocre at best. No engine codes though?
Think i goofed the wiring somewhere? Anyone have ne good ideas?
What harness did you use? Sounds like some mixed up wiring or something. I'm assuming you're using the H22A ECU. If so, might want to check to see if the pinout is the same as the Accord(I remember seeing something where the H22A had some different wiring than the Accord).
Used the accord harness and the prelude brain. They have slightly different pinouts, but i thought i compensated by switchin the right wires. Anyone have any specific ideas as to what i should check? I'm damn near stumped.
bump.
Any specific suggestions? Guess it just needs a complete re-wiring :( :( :(
