h22 major swap problems
Discussion in 'HYBRID -> BA-BB /CA-CD' started by Blk_95_lude, May 14, 2005.
  1. Blk_95_lude
    Blk_95_lude Junior Member
    well, i've got a few big issues i was hopin someone could help me with. I've got the right ecu and im not throwin any codes so im pretty lost:
    1. the car redlines at 6500 and won't go past it at all
    2.the vtec doesn't work, or if it does it's not very strong at all.....i checked for any voltage in the vtec wires at all with the car on and im not gettin any.
    3. throwin black smoke out the exhaust---think maybe the problem is gas realted but im not sure.
    the engine was swapped when i bought it and it used to be an si. my main concern is why the car redlines at 6500 but help in any of these areas would be great. thanx
  2. reikoshea
    Dallas, TX
    Sounds like you still have the P14 ECU...I havent finished my swap into my 92 lude yet, but thats my 2 cents.
  3. Blk_95_lude
    no, im sure i have a p13 and that why im so lost as to what these problems are.
  4. reikoshea
    Dallas, TX
    Are you using premium gas...H22A is a 91+ octane engine. I dont think it would cause those problems, but its a thought
  5. Blk_95_lude
    yeah, i use premium gas and i also changed the fuel filter
  6. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    VTEC isn't engaging, which is why it won't rev past 6500. Strange, though, since you're not throwing any codes. Are you sure everything is wired right?
  7. tab
    tab Super Moderator
    Aberdeen, Washington State
    Do you have a chipped ECU?
  8. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    Either you've got a ghetto-chipped ECU or your distributor isn't wired right. Dunno which wires it is, but you can have a couplea wires switched in the dizzy and it'll do what you're describing but won't throw a CEL.
  9. TeamUrbanChaos
    TeamUrbanChaos Certified H22 Super-tech
    Home Of ThE LoSt Towers
    :ditto:
    you ECU is going into an "open loop mode". for some reason you ECU is reading something that is telling it that theres something wrong which is why it is not engaging VTEC and redlining at 6500..its a safety feature so u dont dammage something reving at 8000 with no VTEC
    you either:
    a) like CIVICiOUS said, have a bull shit programmed chip in your ECU that is causing problems with your car running well
    -----------------OR---------------------
    B) your ecu's reading some kind on malfunction like a sensor or a wiring job which is probably undetected by the OBD system and is causing your problems.
    as far as your black smoke..that sounds to me like a bad head gasket or your car is runnig entirely too rich!!
  10. Blk_95_lude
    I finally got my VTEC to work but it feels like it takes too long, anyone have any info on why it takes so long (tonight it took 25 minutes because i wasn't driving it hard). Also why would a bad head gasket cause black smoke???
  11. reikoshea
    Dallas, TX
