h22 obd1 obd2 ? can i do this?
Discussion in 'ECU's, Electronics, and Tuning' started by imprt92, Mar 30, 2004.
  1. imprt92
    imprt92 Member
    i was wondering if i could do this? i have a 92 lude w/ a h22a swap i need a p13 ecu. i found a p13 w/ a obd1 to obd2 harness if i get the p13 what is the harness worth? i also found a ecu for a obd2 h22 can i buy a harness and use this? if so where can i find a harness? for a obd2 to obd1 set up?
    thanks
  2. radnulb
    radnulb Senior Member
    Sinsinnaty, Ohio
    OBD1 car with OBD2 ECU can be a real pain. You probably want to avoid this setup.
  3. katman
    katman Member
    PASADENA, CALIFORNIA
    since your prelude is already OBD-1 you should keep it that way to keep wiring & ecu aspects simplified.
    You dont need a jumper harness to run the P13 ecu. A P13 ecu will plug right into your existing ecu plugs.
    If you're looking for a P13 ecu, I have a few for sale. They're auto P13's chipped to 5-speed spec. Hit me up if you're interested.
    -katman
