h22 pistons and rods
Discussion in 'Engine Building' started by typesiracing, Apr 2, 2004.
  1. typesiracing
    typesiracing Senior Member
    ny
    is there any reason an h22 pistons and rods won't work in a h23 block with an h23 crank? i think it the same but just checking....thanks
  2. pissedoffsol
    h23 crank has a different stroke, and thus different length rods, than the h22
  3. tab
    tab Super Moderator
    Aberdeen, Washington State
    The H23 has a longer stroke. It might work, but I know that the location of the wristpin is important when it comes to the geometry of the motor. Maybe it's close enough to work, and your compression would be hella high. Also, I heard that the valve reliefs are located in slightly different places on the piston tops.
    Hope I helped.
    Edit: Damn B. You beat me to it.
  4. Import Builders
    Import Builders Senior Member
    LA, California
    I got stock H23 rods on JDM Type-S pistons, with ARP rod bolts on the stock shotpeened rods.
    I know a guy with slightly used, as in 200 miles used, H23 I beam rods, he is letting for for $250 shipped if you like. h23 rods.
    Very good.
    Jeff
  5. typesiracing
    ny
    nah i'm cool....not really sure what i was thinking last night.........but i'm probably going to reuse my crower rods (h23), h23 crank and h22 pistons....thanks
  6. Import Builders
    LA, California
    Crower rods, H23 crank H22 pistons, thats a good combination man.
    Shoot, I made 180+ WHP with a bone stock H23 block, dish piston! And it ran for 4+ years with well over 100k miles.
    Jeff
  7. typesiracing
    ny
    alright so thats what it'll be then thanks again jeff.
