H22 Problem
Discussion in 'General Tech and Maintenance' started by jchrm80, Jul 19, 2007.
  1. jchrm80
    jchrm80 New Member
    Sorry to double post.
    My H22A swapped eg hatch wont start. I went to leave for work and it started up fine and idled. I went to take off and the car just died and now it wont start. I checked over the engine bay to make sure nothing came lose or was leaking. Power comes on, there's fuel pressure it just wont turn over. I was told it may be the coil, Does anyone have any other ideas of what could be happening or what i could check? I did a spark test, and no spark. I grounded the spark plug to the block and cranked it over.
    I was told it may be the coil, so I looked up a coil for a 1993 Prelude, and bought one thinking I had the right part to start trying to fix the problem. I'm not very knowlegable on h22 swaps and I wasnt sure if you kept the external coil when swapping the engine into an EG. Any help would be greatly appreciated.
  2. P7ank5te7
    P7ank5te7 New Member
    Radford, VA
    Symptoms seem like the same ones I had on my D16Z6. What caused me to replace the coil was, with the power on, I got no spark, and with a test light it was extremely weak. I'm not to smart when it comes to the H22 or a Hatch, but I would make sure to use the coil that comes with the H22. -Gary
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    does the motor turn over wont start ? if so check for spark if theres not any it may be a bad dizzy, but if the motor does not turn over at all make sure you motor grounds are hooked up
