In doing an H22 swap into an EG civic, most swap kits do away with the passenger's side transmission mount, leaving only the two front torque mounts, driver's side engine mount, and rear mount..
My question is this:
The H22, in a prelude, uses a front transmission mount similar to the stock arrangement in a EF civic... with a mount that attaches to the front crossmember.
Now, in an EG civic, there is no crossmember to be attached to...
Would it benefit a person to fab a new front crossmember, using the tow hook mounting holes as an attachment point, and lining up a new mounting point to attach the front trans mount?
I can't see it hurting anything, and at least it would bring a little more weight forward of the front tires, improving traction...
Any opinions on this?
