h22 rebuilt
Discussion in 'HYBRID -> EG-EK / DC' started by tat, Dec 30, 2009.
  1. tat
    tat New Member
    hi guys new to this im doing a conversion to my eg with a h22a2 engine i want to now what parts would be the best to use as im planning of putting a turbo on it like pistons,con rods,head gasket,cams and ecu thanks
  2. Matts96HB
    Matts96HB . Moderator VIP
    I believe your best choice in pistons is going to be mahle gold series, and eagle rods probably. re-bearing it and call it good
  3. tat
    tat New Member
    h22 rebulid
    ok cheers what about turbo kits what the best turbo kits and what cams should i go for
  4. Matts96HB
    I would recommend peakboost if you are looking for a complete turbo setup.
    save the money for the cams, just leave them stock for now
    if anything get a good intake mani, and have some headwork done. that should suit you well. honestly though id just save your cash for a nice turbo setup. it's well worth the extra dough
  5. TheBlur
    TheBlur New Member
    FIRST...
    You get the block Sleeved...Do not boost that thing without Sleeving it, FRM Cylinders do NOT handle boost well regardless of the piston choice u run. AFTER you've sleeved the Block..
    Mahle Gold Series Pro' Low Compression Pistons
    Eagle Rods
    Valve Train (For Turbo Applications)
    Boost Controller
    Turbo Kit
    Intercooler
    Injectors (I'm using RDX Injectors with a Custom Fuel Rail)
    Hondata S300 (And a good tune)
    H22's are notorious for HIGH horsepower numbers and even more staggering Torque numbers on boost...live free and drive well.
  6. blowoutj99si
    blowoutj99si New Member
    theblur is right on the money. sleeve that block for sure. for your turbo kit I would recomend that you stay away from peakboost and spend the money on fullrace.
  7. monotech
    monotech Member
    I agree go with Fullrace.
