h22 stroking?
Discussion in 'Engine Building' started by powerdriverh22, Sep 8, 2005.
  1. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    can u use a h23 crank and rods with type s pistons in a jdm h22???
    if any one has what was the compression??
  2. reikoshea
    Dallas, TX
    yes, should be 11:1
  3. nismogod
    nismogod Senior Member
    Deltona, FL
    wrong. h22 crank, with h22 rods and type S pistons = 11:1
  4. powerdriverh22
    spfld, mo
    what about using h23 crank and rods?
  5. lude9593
    lude9593 Senior Member
    Mt. Pleasant, NC
    it'd put you way up there i would say. maybe 12.5 or 13:1. i think the h23 crank is around 5mm longer than the h22. the type-s pistons are slightly taller too so i would just be worried about it clearing the head. just something to think about.
  6. reikoshea
    Dallas, TX
    I was under the impression that they had the same deck height, just different crank and rods. why would there be a clearance problem?
  7. powerdriverh22
    spfld, mo
    the longer the stroke over the h22 stock crank will push the piston closer to the valves. and you dont want a collission with pistons and valves....its a messy ordeal.
    I am also going to be runing crower stage 3 cams so....that is another issue
  8. nismogod
    Deltona, FL
    h22 rods are slightly longer also.
  9. powerdriverh22
    spfld, mo
    are the h23 rods shorter?
  10. reikoshea
    Dallas, TX
    i think so...i would say yes, but i dunno.
  11. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    Connecting rod lengths...
    H22A1= 5.630 in.
    H23A1= 5.571 in.
    Stroke...
    H22A1=3.571 in.
    H23A1=3.740 in.
    :D
  12. nismogod
    Deltona, FL
    h23 crank, h22 rods, h22 type S pistons. factory parts, big compression. lol.
  13. reikoshea
    Dallas, TX
    lol, thats what im thinking. Im kinda kicking myself for not swiping the crank off my old engine.
  14. powerdriverh22
    spfld, mo
    do you not think it will work??
    im gonna get the crank balanced and micropolished
  15. reikoshea
    Dallas, TX
    It will work. Im wishing i had thought about it. A lot has changed in the last 6 monthes...ive really learned a lot. Did a swap on a Ford Ranger....it actually worked...i was so friggin suprised.
    Yeah, use the type s rods and pistons w/ the H23 crank...thats an insane mod...you might need an octane boost to counteract the knock...thats the only thing i can see wrong with it.
  16. powerdriverh22
    spfld, mo
    what are everyone elses thoughts?
    ive done the searches on honda-tech but i coudlnt tell from the posts if this would actually work
  17. nismogod
    Deltona, FL
    check all of your clearances. and make sure to have it tuned asap if everything clears
  18. scottp11
    No, if he uses the H23 crank (a longer crank) and the Type-S rods (longer rods), the pistons will be sticking outta the deck. He's gotta use the H23 rods (the shorter ones) or custom rods with the Type-S pistons.
  19. lude9593
    Mt. Pleasant, NC
    check out this link. it may help you out. just read through it.
    http://www.nonvtec.com/board/viewtopic.php?t=1126
    i'd just be skeptical of the clearance of this setup and the ability to run on pump gas because i think the compression will be pretty damn high. i haven't thoroughly looked through all the info so i could be wrong but that's my first impression. hope that link helps some.
  20. scottp11
    It'll work.... The link is about putting H22 pistons in a H23. It suggests that the piston might hit the head, but.... it also says ...."H23 combustion chambers are 3.8cc's smaller than H22's from the factory that is another big factor you will be needing to take into account." Just a suggestion, if you are worried about your compression being too high, you could use a thicker head gasket to bring it down a little.
    Use the H23 crank, H23 rods and the H22 prelude type-s pistons for a whole .1 bump in displacement! Good luck on your build.
