h22 swap code 41 need alittle help??
Discussion in 'HYBRID -> EG-EK / DC' started by ahcrap, Nov 5, 2004.
  1. ahcrap
    ahcrap Junior Member
    hey i finally figured out a few problems on my h22 swap. but the last code i need to fix i cant and it is one of the essentials. code 41 or heated oxygen sensor. i have the skunk 2 conversion harness and i think that one of the pins on the harness could be wired wrong because the d7 goes to d22 obd1 side and there isnt even an d22 pin on the wiring diagram. but i checked my wiring on the sensor and everything should be working but it could be wired wrong idont know. any help appreciated.
  2. driver1
    driver1 Senior Member
    figure out if it wired right, then if it is than u know u have a bad o2 sensor
