H22 swap ecu p13 or p28
vickers88
Was thinking about doing h22 swap to my 90 accord . I was trying to find out what difference or benifits or dificulty it would be to use the one or the other ecu.
Basically the pros and cons or any added work to use the p28 instead of the p13.
Any help greatly appriciated.
P13 has the correct fuel maps and such. It's set up for the H22A, and the P28 is not.
Originally posted by defajardo@Apr 11 2004, 07:44 PM
I hear some say the p28 ecu is better...
plus no knock sensor
I found that out on cb7 tuner
yeah whens its chipped or chipped for hondata, isnt a p28 for a 1.6 liter single cam vtec motor. the h22 is a 2.2 liter dual cam, im afraid there is more than a slight differance between p13,p28. your motor is going to run way better with the right ecu anyways.
Originally posted by H22AdelSol+Apr 11 2004, 11:21 PM-->
defajardo
:concur:
Unless you are running Hondata, use the JDM P13.
