h22 swap question!!!1=
h22101
im new at this site. i was just wondering will a h22a fit in a del sol or u got do some customizations to fit!!!!!!:confused:
Check out Hasport Performance, Inc. they have the mounts and axles you will need to make the swap work. You will also have to modify the del sol to use the cable type shifter they use. Hasport's mounts are the best and they should come with good instructions to get you started. Good luck.
