i have a 94 accord and want to put a h22 in it can i buy just the motor and ecu and use my stock tranny it has low miles and if there is anything else i would need trying to save money dont have much at the moment
Actually I'd advise that you go ahead and purchase a 351 Windsor crate motor and drop that into your engine bay. Amazingly it will bolt right up using your stock engine mounts and stock Honda transmission. You can even run it as FWD, no drive shaft or rear end necessary. Just go ahead and grab a P28 ECU, it should run that Ford motor with no problems...
