USE THE SEARCH. ITS NOT THAT COMPLICATED.
https://hondaswap.com/forums/index.php?...ic=18004&hl=h22
and in case you missed it in that link...
i'll quote from a post a guy left in my cardomain guestbook...
posted by civicsleeper22 6/14/03, 3:42 pm
Hey man, you wrote me a while ago and asked about my h22a swap into the civic, heres the info you asked for:
1) Engine was purchased from Triple Digit Motorsports in Connecticut for 3000 with the tranny @ 18,000 miles out of a 1997 usdm prelude
2)Everything needed: Shifter Box assembly, conversion harness (i used a p72 ecu), integra gsr, motor mounts, left axle, right axle, shift linkage, bracket kit, wiring harness, trimline fan
3) there is no room for ac or power steering in our years...although supposedly there is enough room to sneak in a power steering pump it would require extensive modification like moving the headlight assembly etc.
4) be prepared to run into stupid shit, but it is definately the most amazing swap!
