h22 swap
Discussion in 'Accord' started by 94tuner, Feb 15, 2010.
  1. 94tuner
    94tuner New Member
    i have a 94 accord ex and was wondering if i swap a new h22 what kinda numbers i would see?
  2. powerdriverh22
    powerdriverh22 Senior Member
    spfld, mo
    what do u mean numbers? the h22 has 200hp 161tq over the 130hp yours has?
  3. 94tuner
    94tuner New Member
    ok. Someone told me that if i get the simple mods to free up most of the airflow (headers, cat, piping) that i would run the low 13's is that true?
  4. DESPAIN
    flower mound TX
    probly not in an accord......maybe in a civic or on a skate board?
  5. 94tuner
    94tuner New Member
  6. 94accordtuner101
    94accordtuner101 New Member
    im trying to do the same swap but i need to kno wat i wld have to change in my 94 honda accord ex to fit 92-95 h22a motor?are all motor mounts the same?or wat i already kno bout the wiring but wat else to deal wit?
  7. BrutalB83
    Rochester Hills, MI
    I guess DESPAIN's sarcasm escaped you. The answer is NO, you will not run 13s in an H22 Accord with simple bolt-ons. In a Civic? Maybe. In an Accord? No. You'd be looking at more like low 15s, maybe high 14s if your engine was in pristine shape, and you dropped big bucks on a high quality header and did some tuning...
    The first thing you need to do is start your own thread...
  8. 94tuner
    94tuner New Member
    From what i found out and im not 100% sure you would have to have the ecu, harness, and motor. Im pretty sure the f22 tranny will work but you might want to get the h22 tranny for the better gear ratios. But other than that i think thats all you need i asked about it in one of my threads awhile back you can probably see it on there.
  9. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    everything will bolt right up....i have seen h22 accords with stock engine just, intake, full exhaust and a msd blaster coil run mid 14's
  10. powerdriverh22
    spfld, mo
    i ran 14.8 with intake and exhaust..
    for the swap it is pretty straight forward. you will have to shave the driver side mount just a little bit to make it fit and the distributor will need to be rewired for internal coil (easy to do) there is a write up on it.
  11. Sc0oByDo0RaCeR
    Sc0oByDo0RaCeR New Member
    Where is the write up? Can I know ?
  12. BrutalB83
    Rochester Hills, MI
    Probably in the reference section or in this forum somewhere. Try searching for it...
