h22 swap
teg91
Hi, i just want to know if its possible to put a h22 in a integra 91 and how.
and what do i need and where do i get.
thx :huh:
i said that cause you posted a swap question in the members lounge
if you click on forums you'll see that each chassis type has its own sub forum where you should place the questions, just as a mod moved it to the right forum for you...
look up top
HondaSwap.com > Hybrid Forums :: Swap Related Questions ONLY > HYBRID -> ED-EF / DA > h22 swap
if you want to know whats involved try searching this website, but an even better research tool would be hasport.com
click on the mount kit instruction page to see whats involved with the swap
their instructions are pretty thorough for the actual hardware part of the swap
running the motor is a bit more tricky
but this is considered a level 3 swap i believe
you'll need axles, ecu, wiring, shifter cables and the whole shifter assembly from an accord/prelude, cooling customization etc
